2007 Octavia difficult to select gear when engine is running
Guys, I hope that someone might be able to help me.
My Octavia is difficult to get in 1st and reverse gear when the engine is running. I have had the slave cylinder and the master cylinder replaced but still no joy.
The clutch isn't slipping at all.
Any Help would be appreciated. Thanks
Firstly have you tried resetting the cable gear linkage?
It can make a massive difference to shifting, and is dead easy.
Edited by softscoop
There is no cable to adjust, the clutch is hydraulic.
The gear linkage is cable operated.
Have a watch of the video.
I was going to post that video too!!! def give it a try, has made a world of difference to people on here
What he said :) Mine was shocking from brand new and garage said it was normal!! Followed the above vid...took a whole ten mins and has completely transformed it :)
Thanks very much for your help guys, I will try this tomorrow and let you know how I get on.
Hi Guys, I have tried the gear linkage alignment but it has made no difference. The gears are easy to select until I start the engine.
