Flashing glow plug
Can someone help me with my octavia my glow plug is flashing after i start my car i already replace 4 new glow plugs and i already check my break lights and it all ok can someone help what is the problem of my octavia
Get it plugged in and scanned for fault codes.
Have you checked the Back lights (especially the brake lights) to make sure they are all working as the glow plug light also is an indicator of faulty brake lights
I already remove all the back lights but still the its flashing...octavia tou 2004 model
Do any of the brake lights work? If not, then you need a new brake light switch (at the pedal). Source this from a Skoda dealer.
All break lights are working signals all my back lights working
my glow plug light was flashing changed switch under brake pedal and it was sorted
Tnx met ill try to chance
Ok, it was worth asking because the brake light switch is a common problem with a non-obvious warning indication.
I think you need a fault code analysis rather than a bunch of guys in the internet guessing now.
