Lock/Window/Indicator problem
Hello,
I have this uncomon, sudden problem.
Open dor indicator is on, when I close pessenger door, all windows go down, exept peaaenger window. Pessenger window is stucked in upper position. All other windows are working. When I unlock the car all windowa go down exept pessengers window...
My bet is the door microswitch. Help please?
Microswitch corrosion in the wire loom to the door. Most common location to find the culpeit is where the cable passes throught the rubber sleeve into the door panel.
Sounds more like a wiring fault if the window is not working too?
Thank you all. One more interesting thing, when I turn on the car, central lock is trying to unlock dors, and does not stop until I lock the doors...
I can not close the windows whit key, they start and stop after few milimeters...
