Winter wheels
I am new to Skoda with a Superb 4x4.
I usually run winter tyres on a 16" wheel. I have been looking around and found that I can widen my search into Mercedes wheels as they also have a PCD of 5x112 with similar ETs, although the centre bore is 66.6mm.
Has anyone used Mercedes 16" wheels on a Skoda?
Any problems fitting them?
You can get spigot rings to reduce the centre bore down to 57.1mm
You also need to check the wheel bolt seat is the same as the Škoda ones .... or buy bolts to suit.
Thank you.
