Climate control issues
That's like a lot of us,     No Issues !  :notme:
Spent 10 mins typing it out and it blank!!!!!!!!
I'll try again!!!!
Hi, I've got a 2006 Octavia II VRS TFSI.
When I put the CC on LO it's seems to block all the vents and won't push any air out.
A slight change to 16 degrees and it's starts blowing again.
Occasionally I have to turn the temp up to 21 + to get any cool air out.
More often than not if the CC is set to less than the outside temp shown on the maxi dot then it's the same story.
Any ideas????
Thanks in advance
Paul
Edited by quinnster999
Have you tried resetting the system - I've had similar previously and a few resets (which re calibrates the actuator flaps inside the CC system sorts it.  From memory, with the ignition on but the engine off, hold down the ECON button and the bottom left button of the four oblong ones for airflow that are grouped together between the rotary knobs. The display changes and then you hear all the flaps calibrating.
Thanks Skomaz,
I have tried that but not for a while. I'll give it another whirl.
Paul
