LED indictors?!?
The octavia is very fussy about bulbs Paul. I must have spent about £20 on various led bulbs. They either blow after a few days or I constantly get a bulb out warning
Sent from my Galaxy S5
Have them and work ok. The problem on my 2010 is that the bulb is tucked or hidden in headlight making the light exposure very low, not bright enough
Where did you get them from and what type are you using? Could you post a link?
Cheers :)
Thanks guys I remember when I first swapped to led side lights I had the issue with car been really fussy
Might try a set of the ones I linked up just to test brightness and see if they work
I'd be tempted too, might try the Philips ones as the Euro is so weak, they'll be cheap in Germany I should think.
