Retrofitting Maxidot from Golf into Fabia?
Curious to see if this is possible and what people think.
As fabia maxidot displays are rather thin on the ground, would it be possible to take one from another car (golf, bora etc.) and retrofit the maxidot either as a complete unit or in part to come together with the fabia VRS I clocks?
Bit of a thinker for you all :)
Im hoping its doable
Why not 6Y0920943S? Or you already have it?
I'm going to say no, I've thought about it and things usually don't match up like speed and the Rev range. I'm sure that can be adjusted but all the same I don't think it fits.
Yes it will fit but you need to swap the housings and delete the Immo
Is that a standard unit or? I don't have maxidot at present.
With u saying it doesn't fit do u mean the golf clock as a whole? What about porting over the maxidot cluster into fabia clocks? I'm going to go out on a limb and say they use the same chipset golf maxi to fabia maxi with identity differences for speed etc.
Delete the immo? U mean the immobiliser? Wouldn't u flash the device and set it up with a new identity that of the fabia?
I'm happy this isn't a definite no!
I'm happy to watch someone try and fail ;)
My real friends wouldn't treat me like this... :P
Why don't you just try fitting an OEM part?
Sorry, don't mean it in a bad way!
I just don't think it's possible and a lot of people say it is possible, so only one way to find out!
Because it's very expensive and rare to find.
  • 1 year later...
An update!
Been scouring the web for more info for quite a while on how to get these installed into a fabia, whether it be either a Bora highline setup, Golf setup or just the original Maxidot cluster.
What i've heard, and what probably everyone else already knows, is there was one person who managed to get one coded in by using Ben at Shark Performance?
I managed to dig out the thread and unless I'm missing something the only problem they had was that the original cluster they purchased was for a CR engine not a PD, once a PD was sourced it seemed relatively easy to create software wizardry and put into the fabia.
Parts seem to be ordered from skodateile.cz
Anyway I'm going to try and compile a list as I find them of information relating to a Maxidot Installation into a PD environment.
LInk is:
http://www.briskoda.net/forums/topic/154237-ive-now-got-maxidot-thank-you-ben/
For reference:
http://www.briskoda.net/forums/topic/330852-instrument-cluster-upgrade-maxi-dot-some-questions/?hl=%2Bmaxidot#entry3976789
http://www.briskoda.net/forums/topic/216975-skodateile/
http://www.briskoda.net/forums/topic/386250-maxi-dot-on-pre-fl/page-3?hl=%2Bmaxidot#entry4550828
http://www.briskoda.net/forums/topic/232263-used-maxidot-retrofit-help/?hl=maxidot#entry2729539
http://www.briskoda.net/forums/topic/230857-maxidot-retrofit-help-in-devoncornwall/?hl=maxidot#entry2712675
http://www.briskoda.net/forums/topic/267557-apart-from-the-stealers-anybody-know-where-to-get-a-fl-maxidot-with-mph/?hl=maxidot#entry3188785
http://www.briskoda.net/forums/topic/242485-maxidot-retrofit/?hl=maxidot#entry2848141
http://www.briskoda.net/forums/topic/230307-maxidot-retrofit-thank-you-to-hobins-skoda-of-manchester/?hl=maxidot#entry2726970
http://www.briskoda.net/forums/topic/177041-brimma-is-pleased-to-announce-a-new-arrival/?hl=maxidot
http://www.briskoda.net/forums/topic/259422-fl-and-maxidot-sorted/page-2?hl=maxidot#entry3106483
http://www.briskoda.net/forums/topic/365225-retrofit-maxidot/?hl=maxidot#entry4330109
http://www.briskoda.net/forums/topic/338448-maxidot-into-non-maxidot/?hl=maxidot#entry4071098
http://www.briskoda.net/forums/topic/323410-maxidot-retrofit-on-vrs/?hl=maxidot#entry3937182
http://www.briskoda.net/forums/topic/194770-maxidot-retrofit-and-fl-vrs/?hl=maxidot#entry2320398
Edited by AaronMountford1990
The newer style CR maixdot would be great.
IIRC Faboka purchased a Fabia maxidot off ebay and fitted it in his, pretty sure its 90% working?
So he's done a used retrofit?
From what I've read if you can get a brand new one (which always seem to be available at skodateile) you can get it dealer installed within 2-3 hours as they just follow the procedure for replacing a "Faulty" dash cluster and send over the mileage, recode the immo to your keys etc.
One post I saw said that all in it was under £400 parts plus installation by a main dealer! Not too bad! I cant comment on whether there are major differences between the PD Octavia and PD Fabia but hey if they are as similar as I hope maybe this puts a silver lining on the dark clouds that come about when people ask about retrofitting Maxidots :) !
The mk2 Octavia clusters are totally different to the mk1 Fabia.
The electrical systems between the cars is very different and nothing like this is interchangeable.
