Sat Nav 0-60
I Was Wondering, is there a peice of software for the Pocket Pc (Windows Mobile 5) that can test your 0-60/0-100/Top Speed E.T.C?
I doubt it would be accurate because the GPS doesnt update fast enough.
Sat nav will give you a very accurate speed, but as Goochie says it will not do so instantly. However it will tell you how accurate your speedo is. Drive on a motorawy or dual carriageway at a constant speed (need a reasonably straight bit). After a few seconds compare speedo with sat nav speed. Mine is about 6% to 8% too high
Was thinking about this too, but the update speed issue scuppers it really. Does anyone know of a program (preferable freeware) that just gives basic GPS info on a Pocket PC - compass direction, altitude, perhaps current speed? Would quite like the altitude info the most, always nice to know and TT5 doesn't display it :)
Steve
I'm not sure about a software for a pocket pc but the G-Tech/Pro SS measures Horsepower, Torque, 60 ft times, 1/8 and 1/4 mile times, 0-60 & 0-100-0 mph, RPM
I'm not sure about a software for a pocket pc but the G-Tech/Pro SS measures Horsepower' date=' Torque, 60 ft times, 1/8 and 1/4 mile times, 0-60 & 0-100-0 mph, RPM’s & Shift lights and handling G's.
Hope this helps :thumbup:[/quote']
So does VAG Com well the version Roo has does anway..
How much does it cost?.........
All details you'll need are at www.ross-tech.com
Or there's been threads on here discussing VAG-COM. Try a search...
Steve
i Remember with my mini-ixt running a satnav software gave me alt. lat. speed. etc.
Speed on speedo read 70mph, but speed according to satnav would be 67mph/ish.
But GPS is only good to a couple of meters, so there will be some inperfections on actually speed..
Speed on speedo read 70mph' date=' but speed according to satnav would be 67mph/ish.
But GPS is only good to a couple of meters, so there will be some inperfections on actually speed..[/quote']
If you are travelling on the flat in a straight line and at a constant speed GPS is accurate to 0.1mph, according to the experts here www.pocketgpsworld.com. It is ceratinly much more accurate than your speedo is likely to be.
