gtb2260 build fabia vrs
Are you going to fitting stronger double springs for the valves with this camshaft? And do you know if it's cut from a chilled cast blank or steel blank? Will be interesting to see how this pans out.
going to keep standard springs, I couldn't tell you tbh could try emailing them I'm sure they'll tell you
  • Replies 56
  • Views 15.3k
  • Bit of an update got calipers powder coated and fitted ended up fitting 8mm spacers to gain clearance [url=http://s567.photobucket.com/user/patrickferguson20/media/Mobile%20Uploads/20160312_1237
  • Intercooler done today waiting on ibiza slam panel downpipe flange lined up and silencer ready for welder and pictures of projectors in daytime
  • bit of an update got 2.5" downpipe ordered for tubular manifold fitted pd160 intake and found a fuel cooler in the scrap yard im gunna use perfect size to hide away just need to get some braided lines
Thanks for the reply, I looked at Winols but thought the paid for version was needed to actually modify/save the maps rather than the test version, could be wrong as I found their website pretty hard to navigate!
there's a few cracked versions around online , might be worth to make a account on ecu connections everything's on there to guide you around mapping, could use vag edcsuite that's a free version but it doesn't show all the maps up so you'll still need to search for them, any questions just mail me il try help you
bit of an update got camshaft fitted today along with new lifters bearings etc all seams well so far, first start up was real lumpy like a petrol cammed car but soon fixed that, the torsion value was 4.4 in vcds after several attempts I've set it at 0
cars now up for sale looking at £4000 il post some pics up if any interest
Did you ever get the boost to come in earlier pal?
What's next?
What's next?
audi a3 ppd170 pal just picked it up yesterday yh got it in a little earlier but didn't feel as strong ending up with surging, I get full boost at 2800rpm running 2.5 bar in midrange than tapering off to revlimit
Planning on modding that? Shame about the injector restriction on them...
Bit of a bugger that... seems you reached the limit and had the veins a bit too far closed. Hope my VKLR hybrid will be better!
