fabia 2 rear door water leak
Please help.... I know fabia 1 had an issue with rear doors leaking but have just noticed a rear door water leak on my 2009 fabia 2. Any help on how to fix would be fantastic.
My Fabia 2 also has a little leak from time to time. I took the door card off - in principle the same method as the Fabia 1. Then gunked a load of window bonding silicone - I had some after fitting some windows to my van, but a decent gutter sealant will also work.
How do you remove the rear door card as I may do it myself if the door card comes off easy enough.
