Columbus and battery drain
Fair play never ceases to amaze me How sound people are I'm this forum, big part of stayin with the skoda brand. I went from mk1 to mk2 vrs
It shows as being compatible (please note that I do not has dealer facilities to check these thing for certain) with an Octavia from 2004-2013 and seems to be a pretty new revision to the CAN Bus. As it is to listed on the Ross Tech page, then according to them, it is suitable.
Cars Equipment are pretty reliable.
I'd say that it will work. But it's your money and you need to be sure.
Thanks, I contacted eddie_nl on briskoda and I think he's going to sort me with a plug and play solution.
If all else fails, ask Eddie-NL.
He'll send you one pre-coded so it'll be straight swap then.
Now comes the fun bit - getting to the CAN Gateway to swap it...
If I have to strip it down to chassis to get it I will
I have pretty big hands and I managed to get to mine from inside the car. I don't know why but it just seemed easier than the thought of stripping external trim off to get to it!
Once you have removed the plastic trim below the steering wheel you can then access the relay board, unclip it and push it out the way. You can then stick your hand in behind it and feel the gateway there. It unclips then you can pull it forward enough to unplug the cable. I never managed to clip mine back in place but that may have been down to the extra wiring and module I also stuffed in there (the polar FIS+).
Phil
Agreed, they are pretty easy to get out but damn hard to get back in!
Good stuff, gateway on the way from eddie_nl, so when I get that the games will commence
Also got black fascia from skoda for 15 euro and a can of Vw satin silver. I refuse to give 65 euro for a painted silver fascia. I'll post up the results
Best to find out which can gateway you have installed now.
Mine is a 57 pate and had a new enough gateway to not cause battery drain.
Phil
