OUTSIDE TEMP SENSOR ! Incorrect temp even after replacement
Hi all, recently replaced the outside temp sensor due to silly readings on the dash display, ie  - 3.5c on a hot sunny day ! and other similar readings. I replaced with a propitiatory make (Delphi) which I believe are the oem suppliers same part number etc all looked good after first fit, for about 10 mins next time I turned the ignition on yes you guessed incorrect temp showing...DOH !   Anyone have any thoughts on what could be causing this problem.
Thanks in advance
Possibly a problem wit the control module the temp sensor sends it's information to vcds will tell all
Sent from my C6603 using Tapatalk
