Flush Cobra Parking sensors
Has anyone put these  flush Cobra parking sensors in their Fabia??
Laserline seem to be the product of choice for flush fit sensors, got them on my monte although they were branded as Skoda ones they're in fact laserline
anyone tried the  new 17mm Cobra ones???
The OEM kit is available here
They are 18mm flush fitting and I have had no problems at all with using them.
thanks but i only want aftermarket flush rear sensors ...
Do they do as it says and display on the swing/Amundsen unit of distance?
This is what I really wanted for mine!
Yeah but you have to route it in and code the HU plus connect into the Canbus gateway. I struggled but was helped out by Phil the Geek on here.
The laserline kit is great then. imho flush fit look great but the surface mount not quite 'OEM' looking
So it's not as simple as just plug the cable in the back and code it through VCDS?
No, not at all. It's not hard or complicated once you know what to do but its fiddly
You have to remove the bumper and cut the holes, remove the boot trim to mount the control unit under the arch, remove the b pillar trim to locate the beeper, connect the twisted pair cables into the gateway and then plug into the head unit. I bought the OEM cutter to make the holes perfect and with the correct bevelled edge
It then needs coding so the HU will recognise the unit and interpret the system
On the ****ometer scale of difficulty then I'd say 6/10
I already have a rear view camera so all i need to compliment the visual is the audio from the aftermarket flush sensor,corbra latest sensor is supposed to be 17mm and flush ,suprised no one has them :(
Edited by john123
Thanks Wakey, think I'll stick with the Skoda kit (laserline) if it goes faulty at any point I'll replace it with the OPS kit
Any pics of the camera fitment per chance?
....sorry but as it was done a while ago during Winter dark hours ,but i followed similiar guides that i had found in the
forum.
I had rear Cobra sensors supplied and fitted to my Monte ,by a company called Parking made easy , from Manchester area, they did not remove the bumper and made a very neat job, the sensors work fine and look good, am very pleased with them.
