best way to clean rusty calipers?
I've brought a set of 312mm calipers for the vrs and started to clean them up a bit before I paint them. I've used a wire brush on a drill but there still a rusty.
What's the best way to get it off and hopefully smooth.
Ant
remove as much rust as you can how you're doing it then give them a coat or two of red oxide paint as a primer.
A wire brush on a drill and a spray with Primer
OR
Powder coating is not expensive..Do a search of firms that do it
Theres one near me called Cas Coatings
They Shot blast them and Powdercoat in a colour of your choice
Heres a good one:
HERE
Cap any "clean" surfaces and sandblast.
When I did a set of mine I just wire brushed them like you then I gave them a coat of rust converter, this is the stuff I used http://www.frost.co.uk/review-granville-heavy-duty-rust-cure. Then I de-greased them and applied some paint of my choice. Maybe a little overkill but I already had the rust converter so I thought I might as well use it.
This is what the looked like E64A7CE5-CF12-4A18-A6A1-3E9180A496F7_zps
44A033B9-85E7-4B73-95ED-FB6632253F57_zps
This is with a coating of Rust converter you paint it on and it looks like milk.
279F2B92-E738-41C6-BFCB-8E9CD618CDAE_zps
14D89570-2043-4E87-9B73-3A9B7494EBB7_zps
Once it dries it turns the rust black by chemical process.
12774C40-BF92-4D71-A6C8-99B5431E77F3_zps
AFE6F47E-4394-4596-B01F-3861CAA2C1CD_zps
Then I painted them giving them 2-3 coats. That little tin you can see easily did 2 pairs of calipers which I brought from amazon.
91FC3E99-98E6-4BF0-8F33-D2F895FD4068_zps
Here's the other set I did.
275A1F29-49CF-4F8C-99FA-EA4A822E7119_zps
2AEEED35-2C23-4879-9D71-0B649D678AFA_zps
I lust gave mine a quick going over with a wire brush as they were still on the car and sprayed them with Hamerite. It's still on and strong As long as there is no loose rust it says it can be sprayed on rusty metal so all is well. As for the drums on the back I gave them a better scrub with the drill brush.
I didn't really want to strip them down. I'll just have to keep trying with the drill and wire brush.
Ant
I gave mine a going over with a wire brush on a drill to get most off it off then attacked it with a dremel and a load of small wire wheels. Ended up lovely and smooth (but not so much that paint doesn't stick)
You won't get them completely smooth without putting in a lot of time and effort because I believe they are made from cast iron. Once you give it a few coats of paint it will smooth out a lot of the ruffness but to be honest you'll never notice them from behind a wheel anyway.
