2.0TSI VRS Lumpy Idle - MIL On :-(
Hi all,
Hoping someone might be able to help a poorly Skoda.... Driving home this evening I noticed the idle was a bit erratic. When stopping in traffic the idle was sitting at around 1200RPM then dropping down in steps until it reached a normal idle.
Still pulls like a train when driving, it just seems to be an idle issue.
Plugged it into Vagcom a few moments ago with the following results...
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 G    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0010
   Revision: AAH03---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 73430 790 00000
   VCID: 3957F655706366F652-806C
4 Faults Found:
000369 - Fuel Trim; Bank 1
               P0171 - 000 - System Too Lean - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 206139 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 07:42:37
             Freeze Frame:
                    RPM: 754 /min
                    Load: 18.4 %
                    Speed: 0.0 km/h
                    Temperature: 96.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
001089 - EVAP Emission Control Sys
               P0441 - 000 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 206144 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 16:42:28
             Freeze Frame:
                    RPM: 749 /min
                    Load: 19.6 %
                    Speed: 0.0 km/h
                    Temperature: 98.0°C
                    Temperature: 37.0°C
                    Voltage: 14.224 V
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected.
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 206139 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 07:43:19
             Freeze Frame:
                    RPM: 865 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 98.0°C
                    Temperature: 51.0°C
                    Voltage: 13.843 V
004688 - Fuel Level too Low
               P1250 - 000 -
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 206213 km
                    Time Indication: 0
                    Date: 2010.01.22
                    Time: 17:41:42
             Freeze Frame:
                    RPM: 857 /min
                    Load: 15.7 %
                    Speed: 0.0 km/h
                    Temperature: 102.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0000
There is also a high pitched noise coming from under the bonnet somewhere too which is new!
Any help would be very much appreciated.
Dan
Edited by brown_d9
High pitched noise could be the PCV? Does it sound like this: https://vid.me/BrcW
It's similar, although yours seemed to make the noise when shutting the engine off, mine only does it when it's running.
Definetly something I will check though!
See if the high pitch noise goes away when you pull out the oil dipstick.
Ok will give that a try, what exactly does that tell me?
Dan
I tried removing the dipstick this morning with the car running, there was a massive rush of air either into or out of the dipstick pipe, the engine coughed and spluttered and then settled down to idle again.
The high pitched squeal did not go away, nor is any where near as loud as that one in the video.
Dan
Any more ideas?
I have removed the plastic pipe from the inlet manifold going to the PCV, blown through it very gently and it will allow air through, but as soon as i blow a little harder it locks up and allows nothing through.
Removing the dipstick this morning actually caused the engine to stall.
When pressing on top of the PCV valve with the engine running, the squeal does subdue slightly and the engine changes tune and seems to run a little better.
I have ordered another PCV presuming it to be this, but any more ideas would be great!
Dan
