PCV location
Hi ave heard a lot about this PCV valve the trouble am having is finding it or even what it looks like.
This am talking about is on a 1.9 PD BXE engine code if someone could point me in the right direction on where abouts this is and maybe some pics would realy help me many thanks.
Graeme
Just curious what exactly does this part do and what are the symptoms of a fault?
Gases that leak from the cyclinders into the crank case will mix with oil causing the oil to clog up and be less efficient.  The gases are instead recirculated back up into the inlet to reburned so less unburned fuel vapour enters the crankcase.
