Smf or dmf?
As title says SMF or DMF. What people got and Pros and Cons. Thanks
And what set up should I be runnin I'm standard ATM but will be goin stage 1 in near future thanks
Edited by Conorpierce1
By stage 1 I assume you mean a remap, in which case simply fit a new DMF, clutch and slave.
Smf:
Pro - cheap
Con - noisey
Dmf
Pro - silent, perfect fit, light clutch pedal
Con - more expencive than a smf
duel mass for 240bhp or less
As above. It's up to you tho.
Try cp4l split the orders and use cp15less code for £100+orders
For a remap you could limit the torque low down and just keep your standard dmf.ssome smf can cause creeping.
After reading millions of threads on here, then applying my common sense, I have opted for Darkside's SMF/Sachs SRE clutch; not cheap (£1140 fitted), but do not want to have to change it again as I know I will be going GTB power in next few months. If you fit a standard DMF and clutch, then decide to go for bigger turbo later on then you will most likely rip it apart within months, depending on how good/bad the mapping is.
There are people running the standard clutch and gtb's with no issues as its as very smooth power delivery.
I have the sachs paddle clutch so I'm set for life....hopefully lol.
Think those few answers are enough to answer the original question, and puts SMF/DMF thread count to 1,000,001 !
Sorry I've only owned my first fabia vrs for 4 days so just want every1 opinions
