electric window switch replacement
One year into ownership and the list of fault on this car keeps getting longer and longer, latest being the electric window switch on the drivers door. Struggling to get the trim removed to replace the switch. Has anyone done this? I tried popping it off as someone suggested but it seems to be on tight and don't want to brake it? Cheers.
It does lever off. You might find some more detail if you look for instructions on removing the door card as some of the bolts that hold the door card on are hidden behind the switch panels in the door. I used a plastic bicycle tyre lever which I sharpened slightly on a sanding belt to get into the gap between the panel and the door.
