Yeti Reversing Camera
I have had my brand new Yeti for just over 2 weeks and last night I was reversing in the gloomy half light and looking all around me using mirrors and rear window etc, I could see a small wall about 80cms high and the reversing sensor was pinging to say I was close but them crunch..... I had hit a small post that the reversing sensors and me, did not see. The damage is very superficial with slight scratches to the rear bumper and skid panel.
However, it made me realise that a reversing camera MIGHT have helped me see the offending post and I know I should have looked before reversing etc...
The reversing sensors did not see or warn me of the post by rapid bleeping.
Does anyone know if the factory fitted reversing camera can be fitted as a DIY job easily?
Has anyone done this on the latest facelift Yeti?
It is a factory fitted option too so all the parts must be available.
Would welcome your input.
got an aftermarket camera .Wireless,so you need not bother sending a wire to the front.Just connect it to your reversing lights and get the front unit powered.Comes with a clear suction cup so you can fit it on the right side of your windscreen with minimum clutter.Costs round us60 dollars.Does the job. Anything else,meaning Skoda original ,is a waste of good money.
Edited by oriki
Could you possibly share the link to camera?
sorry, I am a bit confuses with some of the acronyms,
if I have a 110 4x2 tdi yeti, 2012, with the standard radio,
can I use that ebay camera? where would it plug into?
or does it only work with the top end radio?
thanks
thanks
Simplistically, there is no standard radio, it depends on what "trim level" car you bought. Which is yours?
You will also find the type of "radio" written on the unit.
Interesting that you found a "blind spot" in the reversing sensors' coverage.  While acknowledging that I was primarily at fault, when I reversed into a lamp-post a couple of months back I could have sworn that the reversing sensors were silent until the point at which I hit it.  I was turning on full lock at the time, which is one reason why I think I failed to see the lamp-post: my view of it was blocked by the D pillar for most of the maneuver.  I suspect this may also have contributed to the sensors not "seeing" it (but 'this' i don't mean the D pillar, obviously, but the rather acute angle of approach).
I'm not sure a rear view camera would have helped much in my case, since the lamp-post effectively came out of my blind side  - just about the only downside I've found so far to the Yeti's excellent turning circle.
Sure.
There are many models and makes.Mine has been installed and working over six months flawlessly,so you have a first hand recommendation.The screen is small,but thats just what I wanted.For a quick glance at the screen while reversing it is all I need,and takes minimal space on the windscreen.
The camera mount has multiple options for fitting,I will send you a pic so you see how mine is fitted. It is the best option.Minimal interference with the Yeti electrics.Gets power from the reversing lamp,and just needs a live wire in the front.Here is the link,it is from the American Amazon,but i wouldnt be surprised if the UK site has them in stock too.Copy and paste in the adress bar.
http://www.amazon.com/gp/product/B001W6LGGS?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
Edited by oriki
I had some doubts about the Kufatec canbus adaptor mentioned in the other thread so ordered the one from Car-Equipment. No instructions except :
Connection:
Orange - CAN High
Brown - CAN Low
Red - 12V
Black - GND
Unfortunately mine has different wiring
2 orange/brown or is one brown/orange? Glad I'm not a bomb disposal expert
1 red/black
and 1 black - This has a ring terminal on it so pretty sure that's earth
Presently doing one step forward, two back
BTW Just discovered the door lock is electrically operated,
Just had a mail from the company:
orange with black wire is CAN high
orange with brown strip is CAN low
I must be colour blind. I see no difference
If/when you install it don't forget to use it.
Prior to going out recently I moved my wheely bin to the middle of my large parking area in front of the house ready to put out when I got back for collection the next morning.
Upon return I started to reverse the car into its normal parking space and knowing? There was nothing behind me didn't bother to use the camera or take any notice of the numerous and loud bings and bongs from the warning sensors. You've probably guessed the rest. Anyway the only damage done was a very slight depression in the paint (which wasn't even scratched) where the bracket for the wheely bin handle had just touched the boot lid.
Fortunately it was directly opposite the chrome badges on the other side of the boot lid, so I now have an additional chrome "AWD" badge, sourced from China for £4, which matches the other badges perfectly and balances both sides of the boot lid with badges. Also fortunately is the fact that the car doesn't have any other 4X4 designations on it.
Edited by x19
