Cigarette lighter.
Mcinvrs
Probably been covered a million and one times already but its driving me mad!
Cigarette lighter/socket is knackered. Already tried it with the rear window lock on/off.
Any other suggestions?
Gunna check fuses tomorrow.. which one is it and is there a relay? If so what amp.
Thanks a bunch in advance.
http://www.briskoda.net/forums/topic/175843-fuse-panel-layout/
Fuse 41 and 15A according to this.
Have you connected anything other than the ciggy lighter and USB charger to it that could have blown it?
Could be that your cigarette lighter has a short circuit and has caused the fuse to blow. If they work in the way I expect (nichrome wire) then you could measure the resistance of it with a multi-meter - using some basic equations if the resistance is less than 1 ohm I'd definitely replace your ciggy lighter. Might try measuring mine later out of interest.
