Speedo problem urgent nct due
Iv a problem my speedo and rev gauge just drop while driving sometimes it works sometimes won't work at all need a solution cause it's in for nct Thursday
Another common problem. Make a search in the box at the top and you will find many threads. Here is one of the best:
http://www.briskoda.net/forums/topic/199117-intermitant-speedo/?hl=%2Bspeedo+%2Bfault
In summary, it is probably due to a dry joint around the voltage regulator(s) on the printed circuit board.
Temporary fix may be had by removing a fuse if you are lucky, just to get you through the nct.
Somewhere on here is a very good guide to taking out the cluster and repairing the pcb.
Thanks mate hope it helps
