fitting leon brembo's
Do these fit straight onto a octavia 1U?
Do you need to change discs too? I.e are they bigger on the brembos? If so are the mounting points for the calipers ok where they are or do you need brackets?
I will be doing this upgrade at some point but just wanted to know if it's straight forward or not.
Cheers for any info.
Aaron
Easy to do as long as you get the complete set up, calipers, brackets, disc and brake lines, 312mm V 323mm disc size
Thank you
i had to use 5mm spacers on standard octy spiders, and that was quite tight!
