Fast road set up on mk1 fabia vrs
Hi i was wondering if anyone has a good setting for an aggressive fast road setup on the tdi fabia vrs, ive got kw v1 coilovers fitted but they arent set up as how i want them to be
any help is appreciated
adjust them then
do you get many aggressive fast roads up there then?
I had one yesterday, was overtaking me and trying to punch me through the window
did it know who you were?
I believe so,
KW V1 aren't adjustable (apart from height)
You need V2 / V3 to start fettling damping etc :)
You could look at having it corner weighted. But I'd be more concerned about having the right ride height so that you don't run out of suspension travel and hit the bump stops.
'Aggressive fast road setup' I've heard it all now.
Edited by tommccabevRS
I'll be more worried about having decent brakes if your driving fast.
The "Ronnie Pickering" Suspension setting then??
Who? :)
Do you not know who he is John?! :D
Those kw's should handle pretty good as they are, I have the weitecs which are not quite as good as the kw's and mine handles superbly. I'd look at getting a upgraded rarb if you haven't already and fit some decent tyres on the front.
After that if it still doesn't handle very well then you have something wrong.
Lol yes hence the face.
The replay should have been Johnny ******... Lol
My sarcasm obviously didn't come across well on here ha ha!
As in... do you not know who he is... He's Ronnie *****ng Pickering!!
Sent from my D5503 using Tapatalk
Lol fail by me. :(
lol i ment fast road set up, dont know why i typed aggressive, but thanks for the sarcasm lads really helped....
Fast road setup is down to what you want to spend.
Ideally... 1756/2260 turbo with nozzles and supporting mods (clutch and FMIC), decent coilovers, RARB, at least 312mm front stoppers with good pads, and most importantly.... a LSD so you can get traction out of the corners!
Oh... and decent tyres!!
All the mods in the world wont allow you to drive fast on a 'fast road setup'.
Just means when you run out of driving ability you will lose it in spectacular style
Roadcraft is a good making progress setup :)
:thumbup:
A "Fast road setup" ?
Either sink £3k into an eight year + diesel barge to make it reasonably quick in a straight line, or sell up and use the money to buy something designed to go around corners.
JRJG
i ment geometry wise... but theres not a lot that can be done....
