VCDS Engine Security Acces Code
Hello, can anyone help me with the engine control module security access code for a 2007 Mk2 Octavia? Its got the 8v 1.6mpi petrol engine, Thanks in advance.
What are you trying to do and can you add an autoscan?
Sorry about the delayed response, please see autoscan below.
Wednesday,07,October,2015,11:12:15:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: ######1Z#########   License Plate:
Mileage: 176760km-109833mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ######1Z#########   Mileage: 176760km/109833miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 FD
   Component: SIMOS71 1.6l 2V     8723
   Revision: --H03---    Serial number: SKZ7Z0F3823943
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 66C350135192162E0EF-8033
1 Fault Found:
16864 - Coolant Fan Control Circuit 1
            P0480 - 009 - Electrical Malfunction
             Freeze Frame:
                    RPM: 0 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 85.5°C
                    Voltage: 12.65 V
Readiness: 1110 1101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8DA5776E8867E6AD9-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   Shop #: WSC 00000 000 00000
   VCID: 3467FA5B57CEB4BE40B-8061
3 Faults Found:
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
01317 - Control Module in Instrument Cluster (J285)
            013 - Check DTC Memory
00818 - Sensor for Evaporator Outlet Temperature (G263)
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004434382
   Coding: 10040E031004140023110D000000000000097B075C
   VCID: 2A5BE423850AF24EEA7-807F
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00063477
   Shop #: WSC 73430
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 06 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0BLMN0
   Coding: 0012342
   VCID: 7DF11F7F2404B5F6FF5-8028
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 800FE68BD3F6581E143-80D5
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 812 B    HW: 1Z0 920 812 B
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0F3823943
   Coding: 0000101
   Shop #: WSC 73430 000 00000
   VCID: 3365F94752C0B386591-8066
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 176764 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:08:45
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001069070587
   Coding: 3D3F034007001302
   VCID: 2C57E23B8FFEEC7E18B-8079
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326BFC43ADDABA8E527-8067
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 18801A085283003F3F04850500004F01807CA0
   VCID: 8305E987C2E04306091-80D6
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Component: Tuer-SG         005 0943
   Coding: 0000244
   VCID: 3979CB6F70AC49D693D-806C
Address 56: Radio        Labels: None
   Part No SW: 1Z0 035 152 C    HW: 1Z0 035 152 C
   Component: Radio YD5           0003
   Revision: R0004000    Serial number: SKZAZ2F4903749
   Coding: 0100200
   VCID: 2E53E833B9E29E6E36F-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377DCD5746B85FA6659-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
   VCID: 387FCE6B4BA650DE6C3-806D
End   ---------------------------------------------------------------------
Your VCDS needs updated we are now on 15.7.1
Thanks for the 'headsup,' it's not mine but it's all I had access to. I am not looking to clear error codes, I hope the autoscan result above will suffice.
Somebody help, please.
Is it a genuine version of vcds?
Sent from my D5803 using Tapatalk
I don't know if it's genuine, it's not mine, I paid to get it scanned then.
A genuine, up to date version of vcds should give the access code in a little pop up bubble thing.
Thanks all, sorry I've been away, haven't got my hands on a genuine vcds yet.
