Feedback Independent Garage's In & Outside London Area
For reviews and feedback on garages in and outside the London area, within the M25 & a radius of 60 miles outside the M25.
Format should be along the lines of:
Garage Name: ACME Garage
Telephone:
Address/postcode:
Website:
Work carried out: 3rd service, original parts used
Review: (good or bad) but within reason.
Edited by BATVANVRS
Formatting / outline
Garage Name: Russell Automotive Centre
Telephone: 0208 200 0995
Address: Kingsbury, London, NW9 8AU
Website: http://rac-london.co.uk
My Car: Skoda Octavia VRS 2.0 Petrol (63)
Work Carried Out: 3rd service, genuine original parts used, oil, oil filter, pollen filter, Inspection and Lubrication service. Service interval reset, also had air-con re-gassed (not part of the service)
Review: First time I've used these guys & the service was great, I waited in the waiting area which has a big long glass window so you can see the mechanics working on vehicles, service was around 2hours & 30mins, based on the level of service I received, I would use these guys in the future.
EDIT:
But when I got home I found the 2 black screw caps for the air-con pipes left by my windscreen scuttle panel (wipers area) so the mechanic forgot to put these back on, luckily I didn't have to travel far to get back home otherwise they could of easily been lost. (easy mistake, not a major one)
Vehicle service wise so far so good & have no doubt in recommending this garage to fellow Briskoda members based on my review.
Edited by BATVANVRS
  • 11 months later...
Garage Name: Unit18
Telephone: 01908 320 043
Address: Gallon Wharf, Old Wolverton Road, Milton Keynes, MK12 5NL
Website: http://www.unit18.co.uk/
Work Carried Out: 4th service carried out at 34,420 miles, genuine parts used, oil, oil filter, air filter, pollen filter, DSG filter, DSG oil, spark plugs, oil seal, brake fluid, front brake pads, Major inspection service, Service interval reset.
Review: Second time I have been to Unit18 (1st time was retro fit cruise control) & the service I received is spot on, much better than any Skoda main dealer has to offer especially when it comes to knowledge & customer satisfaction, Jason from Unit18 worked on my car with everything done to perfection, overall time was around 5-6 hours & the great thing is! that you can even chat to the mechanic while he is working on you're vehicle & you can clearly see everything that is being done, Unit18 is my main place for my Skoda vRS 2.0T petrol for anything that needs doing, 100% recommend using these guys, friendly & very honest, I travel from London to Milton Keynes which is around an hour there & back, I could easily use a few Skoda Main Dealer's/Independent specialists around my area but to be honest the service from Unit18 is second to none, I can't rate them enough.
Edited by BATVANVRS
Garage Name: Unit18
Address: 114 Tanners Drive, Blakelands, Milton Keynes, MK14 5BP
Work Carried Out: 5th service carried out at 39,520 miles, genuine parts used, oil, oil filter, new sump plug, air filter, Service interval reset, work carried out by Alister & Tom :thumbup:
Additional Info: Also had a Cat-back Remus fitted today with the Remus remote control to close/open the valves, supplied & fitted by Unit18 & sounds absolutely amazing especially when in manual mode using the DSG paddles.
Review: My 3rd visit to Unit18 & definitely won't be my last, always first class service received from these guys & very honest. 5 star recommendation.
Garage Name: Unit18
Work Carried Out: 6th service carried out at 44,539 miles, genuine parts used, oil (5w-30) oil filter, new sump plug, air filter, pollen filter, brake fluid, air-con (re-gassed) hunter 4 wheel alignment (not part of the service) Inspection and Lubrication service, Service interval reset, work carried out by Lee who did a fantastic job with top quality workmanship.
Additional Info: Also had Unit18 fit my new SuperSkoda honeycomb front grille, always efficient service & very reasonable pricing (something I wanted to do but just not had the time recently & Unit18 done this with ease)
Review: My 4th visit to Unit18 & it just gets better & better every time :thumbup: a friendly bunch of guys & also not to forget Deb on reception, Deb is friendly gal & knowledgeable when it comes to customer's vehicles, parts & day to day operation of Unit18 B) always first class service from the whole team/staff with honest & trustworthy workmanship, they never fail to impress me or my vRS :) Thanks guys.
  • 4 weeks later...
Garage name:    Vagtek Ltd.
Telephone:  0330 133 0585.
Address:  Rear of 1, Central Parade, St. Marks Hill, Surbiton. KT6 4PJ.
My car: MY16 Octavia 1.4 SE L Combi.
3rd service plus MOT and brake fluid change.
First time I have used this independent.
Great service, car collected from and returned to home address, no mistakes in setting service interval reminder, quick turn-around and prompt upload onto DVLA for issue of MOT. Cost was less than Dealers quote.
Garage Name: Unit18
Work Carried Out: 7th service carried out at 49,579 miles, genuine parts used, oil (5w-40 Liqui Moly) oil filter, new sump plug, pollen filter, front Brembo brake pads, Inspection and Lubrication service, Service interval reset, work carried out by Lee who did a fantastic job with top quality workmanship as usual.
Additional Info: Also had Unit18 supply & fit a Racingline R600 intake with the turbo inlet, black hose & coolant hose all Racingline products.
Review: My 5th visit to Unit18  B) always first class service from the whole team/staff with honest & trustworthy workmanship, they never fail to impress me or my vRS :) Thanks again guys.
  • 1 year later...
Garage Name: Unit18
Work Carried Out: 8th service carried out at 52,760 miles, genuine parts used, oil (5w-40 Liqui Moly) oil filter, new sump plug, new spark plugs, pollen filter, R600 air filter clean, Inspection and Lubrication full service, Service interval reset, work carried out by Lee who did a fantastic job as always with top quality workmanship as usual.
Review: My 6th visit to Unit18  B) & nothing more to say than what I have already said prior/above...Echo
  • 10 months later...
Wheelbase Garage Ltd
Good Garage Guide Reviews
I had the dash light up like a Christmas tree on the way to Ireland. ABS, ACC, TPS, HHC, ESC, Cornering Lights, Front and Rear Traffic Alert, Lane Assist, Front and Rear Parking Pilot and Blindspot detection all unavailable. Called all the “local” Skoda Dealers and none could see the car for three weeks or four if I wanted a chargeable courtesy car.
I called Wheelbase last Saturday and the 280 was booked in today 10th August with a free courtesy car. The problem was solved (failed wheel Speed Sensor) and they corrected the off centre steering wheel too.
Brilliant service, great prices and very, very nice people. I’ll be getting the car serviced there from now on. Recommended unreservedly.
