Rapid spaceback 1.4 tdi dsg stop problem.
I have rapid spaceback 1.4 tdi dsg and sometimes my car is stopping. I videotaped this problem. In light ramp, After running car, cancelled s&s and open aircondation, Pull your foot from the brake after push gas pedal when its brake from hillholder pull your foot from gas pedal... car is stopped.
And writing on screen "run the engine manually"
İf you have same problem please share your views...
I am from Turkey...Thank you...
https://youtu.be/Y3MksAmRxcA
Edited by Mehmet41
Sorry, I cannot access your video but are you saying that your car stops when you take your foot OFF the accelerator on a hill? DSG has a clutch like a manual car but it will release it for you. If you do not give it enough gas to release the clutch and go uphill it might stall and roll back after the hillholder releases. (Hillhold gives you a few seconds to pull off smoothly). Hope that helps.
