Help with single din after-market audio.
Hi,
This is my first post, so big hello, and if i ask some stupid questions please bear with me :)
I have Octavia 55 plate with stream audio (Climatronic, maxi-dot). I am planning to replace it with sony cdx-gt450U (not the latest thing but I just removed it from previous car and don't want to spend on new HU at the moment). Now the questions i have
What sort of parts I will need (i have searched the forum so i might have slight clue)
1) do I need adapter/cable (also i would like to retain steering wheel controls)
2) Sony HU is single din, any recommendation for fascia
Is generic parts are good enough or should i go for genuine Skoda parts (if there are please provide the part no if possible), the car is in mint condition I don't want to mess up the look of interior (apart from single din HU) :)
Any suggestion/help/advice is welcome.
Thank you
Edited by Nil
I'd recomend Skoda parts to start with.
The list of bits i'd recomend you get are as follows:
Single din adaptor kit from skoda (make sure they supply the correct facia adaptor)
Quad block loom adaptor which also turns the canbus signal into a switched live.
You will be looking at around the £120 mark
http://www.caraudiodirect.co.uk/install-adaptors?brand=35&cat=580&dir=desc&order=price
Edited by ryan-re
Hey Ryan,
Thanks for quick reply. from the link you posted i believe "Connects2 CTSSK002.2 CAN-Bus steering control adaptor" is the correct thing, i might just email car-audio and make sure as well.
i think it is yes.
If you email cad they are pretty good with replying and giving as much info as you need.
I went direct to connects2 to make sure but cad should be able to help too.
You can get the bits cheaper but the skoda kit is a single piece unit for the headunit to sit in and a single din sized cubby hole. They also include aerial wiring, facia trim (make sure you get the right one as there are loads). So a lot of stuff for the £80
