ABS fuse on battery.
Hi guys, when I put my battery in the boot I removed the plastic cover with all the fuse numbers on so I'm struggling to find which one is the ABS fuse, can anyone point me to which colour the wire is as they are all colour coded as well as numbered.
This is the one that goes on the fuse box on the battery not the one in the cabin.
Cheers!
Red/Green 4mm2 wire coming off a 40A strip fuse.
Also seems to be another red/green wire 2.5mm2 coming off a 25A fuse and a red/white 1mm2 wire coming off a 10A fuse, all going to the ABS module.
Not sure if all three are in the battery fusebox, maybe just the first two?
