Octavia Facelift Climate Panel with Bolero Surround Trim
Octavia Facelift Climatronic Panel with Bolero Surround Trim
Climate Panel
Part Number: 3T0 907 044AR
Condition: Used, Fully working I tested it in my car
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 0201AD7795ECF12E4B-8056
No fault code found.
Surround Trim
Part Number:1Z0 858 069
Colour Code: BE9 (looks like siver check pattern) I think it came from an elegance
Condition: Used, has a small scuff see photo (hardly noticeable)
Price £80 Delivered
£70  Delivered
or will split
Climate panel £50 Delivered
Trim £20 Delivered
No one interested?
£55 Delivered
or will split
Climate Panel £40 Delivered
Trim £15 Delivered
Eddie, I saw in a post about retro-fitting this to a pre-FL (07/57) that you mentioned a loom? I'd quite like this upgrade but don't have the time/inclination/patience to start cutting and soldering wires. If there was a 'plug&play' option however...
I can make a loom a semi-plug and play loom for an aditional £25
It requires moving pins form the plugs (fairly easy) and inserting them in other plugs (instructions provided)
Still available
Still available
Eddie, did the loom you mention get over the problem with the Recirc?? I have an 07 with 2 motors not one and apparently this was an issue so I sold the one i had.. but could be tempted again if you have figured out a way to make it work
The loom will wire the two motors in parallel
Panel and Trim reduced to £48 Delivered
Will accept offers
send me a PM
£20 delivered
Am I right in thinking that it shouldn't be hard from the p/fl version to this if so then I will have it
Sent from my SM-G925F using Tapatalk
It can be fitted without doing anything - but there will be a few issues, namely it won't remember the last setting when the ignition is switch off and the the car will mist up if the recirculation flap button is pressed.
To overcome the issues some wiring needs to be changed which will allow it to work almost as it should.
Changing the twin flap to a single flap and installing an Air quality sensor would make it work like in a facelift
So I take it the f/L has a single flap rather than a twin flap would it be costly to convert
I know with VW some late 2007 - 2009 cars have a single flap, although not a 100% sure if it is the same with skoda.
You probably could pick up the single flap cheap enough from a breakers, but would a few hours work to change it.
some people have wired both flaps in parallel
PM sent.
SOLD
