No boost :-/
I was driving along (40mph) and had no boost. So I turned off engine and started it again and I had boost again. Was back to normal!
I had the same issue in my last VRS. Any ideas?
TIA
Joe
Going to say my old favorite the brake light switch.
What u mean?
Dodgy signal from it tricks the ecu into thinking the cars braking and so cuts power. Could be limp mode in which case a code could have been thrown so worth a scan. Could be the old 17705, check a sticky in this forum and Ross tech website for info.
Didn't you recently change your downpipe? If so, are both the lambda sensors installed and plugged in correctly?
Yeah I did and it's all installed properly.
I'll check the other bits that the other guy suggested too.
