TT lower arm bushes
Hello
I've a FL vrs hatch and the front lower arm bushes are worn. I've sourced a pair of TT bushes with the housings. I have searched and can't find an answer.
Can I fit these housings to my car?
Thanks.
You should be able to but check the bolt hole position on the side with 2 holes.  One of them has to be slotted about 1/4".  The arm offset is also different but this may be a good thing.
This might help
http://www.golfmk5.com/forums/showthread.php?p=3410449
Ok thanks. Looks like I'll be pressing swapping the bushes and housings over.
Depends how good you are with a round file. :p
What needs to be modified? Has anyone done it? Is it worth it?
One of the holes may need elongating by 6mm - check first to see  if you have a problem.
What are you referring to in Q2 & Q3?  The bush upgrade?
Yes, I fitted S3 bushes (and arms) - really good upgrade.  The bushes are like chalk & cheese.
