Replacement Car battery
How much im i looking at to get a new battery 12v 70 ah ???:confused:
I think I saw one in a dealer today for £90-ish.
But give the charger time; you'll probably be OK. A bit of deep discharge often does batteries good (well it does in submarines, anyway).
The genuine one is -
000 915 105 AF
72AH/380A
£90.22
I'm sure you'd get one cheaper, have you contacted the dealer regarding a warranty replacement?
000 915 105 AF
72AH/380A
Yes as long as it is physically the same size.
A serviceable battery shouldn't fail just because you have allowed it to discharge fully on one occasion like this.
:iagree:
Deep discharge = bad
Normal discharge/charge cycle = not that bad, as that's what it's designed for.
Marine batteries can cope a little better as they tend to be designed to withstand a deep discharge without permanent damage.
Normal discharge/charge cycle = not that bad' date=' as that's what it's designed for.
Marine batteries can cope a little better as they tend to be designed to withstand a deep discharge without permanent damage.[/quote']
I will check it in the morning Fingers crossed :thumbup:
Flattening a battery trying to start a car ........ should`nt mean
you cant recover it by charging ..... unless one of the cells has died ....
but if a flat battery is left flat for a while ...then it will sulphate and
die permantly :thumbdwn:
What Pete described is exactly what happened to me when I plonked a new battery on the Rover - the original one had been flat for a month, but the new one was driven around for a while to charge it post sticking it on. Problem was that I left it again for a few weeks without charging it fully. Add a bit of frost for a few nights, and it was duffed again. That one I may just be able to recover if i'm fast enough :)
