led dash lights, what bulbs
so wanting to solder in new smd bulbs for my Fabia's dash cluster
does anyone know what SMD chips i'll need for my dash e.g 0603 smd, 5050 smd etc?
it's a mk1
PLCC-2  SMDs. 3528
Edited by TMB
PLCC-2  SMDs. 3528
brilliant thanks, will get some ordered
No probs. I hope you're good at soldering. The SMDs are tiny!
They're not too hard if you've soldered before, just gets annoying with how small they are.
Just had this done on my fabia by a bloke in Essex. Not too hard tbh, just seems really fiddly. Ill post pics up once im on the laptop :-)
Cheers all, yes, I've soldered components on PCBs before so shouldn't be too bad
Is it only the main dash cluster you're doing? Some of the other switches use 3mm LEDs too
doing the switches too, have ordered some 3mm leds
The asr and heated window switch will most likely need a resistor too
mine has neither being a Classic :D
Not got a heated rear window?
How many of the bulbs are needed for the conversion? Just out of curiosity so I can order some in advance. :)
24 exactly for the dash
