rear reg plate removal
Anyone know how to remove it? Ive looked underneath the plate and theres two screws that i cant possible get to from the outside. Thanks in advance :)
The plate is either screwed on or stuck on using sticky pads.
This is my Octavia, you can see the plastic clips that the screws go through.
Ignore the rusty holes pierced with a self-tapping screw. Dodgy dealers for you!
It might be that your plate is held on by being clipped into a number plate holder like this, in which case you simply pull the plate off by getting a screwdriver or your fingers behind it. Once the plate is off you gain access to the screws to remove the holder...
Edited by silver1011
