Paint on exterior plastic trim
The old dear has managed to get paint on the bumper of her Mini - fortunately none on the paintwork, only the black plastic exterior trim (see photo - not actual car although it is the same model - for illustration purposes only!) - would it be ok to use turps to try to get this off?
Hi Brian,
Very unfortunate that, that has happened.
I'd try something less chemically as a first.. personally I'd try either..
A pencil rubber - gets polish of exterior trim, could possibly work.
1:1 dilution of IPA - Neat if that doesn't work.
If push comes to shove I'd try white spirit/paint thinners. I'd advise washing thoroughly after doing this and adding some trim protection like Krystal Kleen Details Trim-X / 303 protectant.
Sent from my SM-G925F using Tapatalk
Cheers Karl - just one question :blush: - what is IPA (other than Indian Pale Ale :D !)?
Edited by Brian69
IPA = Iso Propyl Alcohol
First question usually is.
What kind of Paint.?  (& How much paint?)
ie,
Household Water Based.
Something like Hammerite.  Or something else?
Has she spilt wet fresh paint and how long ago.
(what colour)
Edited by GoneOffskiroottoot
George - household paint (someone left some carelessly discarded in a car park) - I'll check the colour tomorrow when it's light. It happened a couple of weeks ago.
ChrisRS can guide you through it with more care than me.
I was only asking colour to know how obvious.
Personally for household paint i start with White Spirits, at the least obvious spot and a very small area, very carefully.
But i have a whole choice of chemicals and alcohols that i can either get to work, or make a mess with.
Unless you have a detailer near you know, go ask at a body shop.
It's a light colour (white / light pink from memory), so noticeable.
Thanks George
You've already said what I would start with
Test on a very very small inconspicuous area if you can
Some White Spirit on a cloth should be the first port of call, if its household paint
Then wipe with an All Purpose cleaner before applying a trim dressing
If this fails, then its probably Automotive paint, so a different method will be required...and more risky
This is where a second opinion may be required, but some IPA or some cellulose thinners in another inconspicuous area may well be successful
Take your time
If this isn't working...go to a body shop and ask for advice. They will have experience of this already I'm sure
But will possibly charge you
Good luck
Here's the damage -
C171251C-AB24-4241-AA58-59233AD1007B_zps
I would have a go with what I recommended
Let us know how you get on
