Which drop links Octavia vRS FL 1Z
Just after a bit of advice on adjustable drop leks for the above.
The car is fitted with APX coil-overs and is running 40mm lower than standard on the front. I need links around 240mm between centres and have tried a couple of sets of eBay adjustable ones. They are cr@p quality. To the point where i stripped the threads in one of the nuts while tightening by hand with a 17mm spanner.
Has anyone got any suggestions one tried and tested good quality ones?
Have you found any suitable?
