Rear fog lights. On as side lights
Changed bulbs side lights blew now fog lights on as side lights has any one had similar problems. Thanks. Paul
You've put the bulbs in the wrong way?
When you say side lights I presume you mean tail lights?
Did you fit the correct bulbs, they are 566 with offset pins, not the ordinary stop/tail type.
Edited by TMB
Thanks for your reply's i will try your suggestions
Thank's for your suggestion's I will try them later
The foglights function as tail lights in the event of total failure of the rear lights. Check new bulbs and you should be fine, and normality resume,
Edited by mannyo
Thank you for your comments & solution's now all working. Bulbs in wrong way (off set pin)
Thought so :D
There's only one fog light on mine, the N/S has no wiring, so the 21watt filament in that bulb is redundant, it only functions as a tail light using the 4watt filament.
