Fabia 2 estate, parking sensor problem
My 2010 estate parking sensors started to illuminate on dash screen gave a beep and went off. By reselecting reverse they would work normally. Now I get a beep display comes on beeps and vanishes. Had trouble when car new and under warranty garage repaired and said they had replaced sensors and a problem had existed with loom, but that time sensors came on beeped constantly. Any suggestions please.
Hi.
I have just had pdc issues with my 2012 fabia 1,2 tsi.
The fault is that sometimes the pdc is not working at all, or only the acustics work but nothing on the swing display.
The garage changed the reverse sensor on the gearbox, but that dit not solve the problem. They found that the swing radio was causing the problem. In my opinion the radio worked just fine. After changing the radio the problem was gone... I stand corrected.
Now i hope the problem stays away...
Hope you can use this info.
-- Lars--
Denmark
