mk1 Fabia Vrs Electrical faults?
Hello guys,
My mk1 fabia vrs is soon to hit 150k miles emoji_1F601.png But has recently started to reveal some problems:
1. The most commonly occurring fault is that when you sit there with the car running for extended periods of time all of a sudden nearly every warning light on the dash will appear and the power steering will be lost (power steering warning light also on!) so I try turning the engine off and back on but the engine will not even attempt to turn over resulting in having to bump start the car (luckily it's only happened when someone is with me).
2. At other times when I start the car the power steering warning light will come on straight away and I will have no power steering (I've just topped up the power steering fluid level)
3. And this fault I have only experienced yesterday. I started the car from cold and went to pull out from my road and the car sprung up all the warning lights, it seemed to try and stall for a split second and I lost power!! Then all of a sudden it returned back to normal and the car beeped 5 times in a row
4. This I also only experienced yesterday was I unlocked the car stuck the key in the ignition and when I turned the key to second ignition none of the pre ignition lights came up and the trip computer and time in on the dash reset but the car started fine!!!
Sorry about the length of this post but I'm confused as to these faults and need some help.
Thanks guys!!!!
