Why does this EGR pipe keep breaking?
Had the EGR pipe replaced by a local garage as it was split.
Couple of weeks on and I've just checked and its split again.
Is been noisy since the garage done it so wondering if they split it when installing
Any reason that they would split?
Before the garage replaced it for the first time they did the turbo so wondered if they split when doing this.
What's the reason for the corrugated bit? Seems to just make it weaker.
Edited by dany2010
The corrugated section is a flexible section designed to combat vibration fractures, you're supposed to pull the pipe slightly to open the bellows before installing it so that the flexi section is compressed slightly, not under tension because it is stainless and will split.
Your garage used an idiot who installed it incorrectly.
Thanks. Just going to get another one and do it myself.
How far should you stretch them? These wernt stretched at all.
Currently.bodged.with exhaust tape to get me to work tomorrow.
Hate Sundays. If one good.motor shop opened they would make a killing on DIY trade. I always seem to have to invent bodies to last me until I can get back under.
Sent from my E2303 using Tapatalk
Some ECP branches are open on Sunday now.
Sent from my D5803 using Tapatalk
something isn't seated correctly, usually the egr cooler. Is yours a BLT engine?
It is James.
Currently blocked the pipe of. Just get a egr dash light bit its drivable.
Goto the stage where I could only just get up the hill getting out of my road.
