Service
Anyone know how to change the service from a veriable service to a fixed timed service?
Reset using the instrument cluster will set it to fixed :)
Edited by Tom_vRS
Cheers Tom :)
Just be aware you can only change from variable to fixed manually using the dash.
If you want to go back the other way (fixed back to variable) then you need a dealer or someone with VCDS.
Cheers Silver :)
