what more parts do i need to get 260hp out of my vrs
hey guys here is the list of things i have on my car
(1) 3" downpipe with 200cell race cat
(2) 2,5" exhaust from the cat and back
(3) an upgrade turbo suitable for 260 hp based on the original turbo but has bigger compressor and other design inside
(4) 375cc injectors bosch 0280155830 blue volvo t5 injectors "not installed yet"
(5) a stage 3 map  based on my bigger turbo my bigger volvo  injectors "not installed yet"
i have original air filter in the airbox
and original tip on the turbo
and i have an original intecooler
and right now i have a very mild stage 1 map installed
the stage 3 map will be installed when we install the bigger injectors
Bigger tip my advice, where did you get turbo from?
okeej is that all i need ??  i bought the turbo from a turbo restoring and tuning company named turbotech here in sweden where i live
they have a websight
www.turbotech.se
Hey bud,
Think you'll also need a decent intercooler, the standard set up will be too restrictive on air flow.
Hey bud,
okeej yeah im thinking about a toyosports one  or a wellycooler cant deside wich one though
They are the same mate, welly is nickname for the Toyo sport one
aah okeej my bad hehe i thought the welly cooler were the nick name for the bigger ones for example the 600x300x76
:P
Yeasshhh the bigger boom ting one. I have a forge at the mo but want the welly. Better flow
aah okeej did you notice increase of power after you installed fmic
I did actually, can't tell you my before and after bhp but it felt quicker.
Ah okej do you have a bigger tip also
You'd be better off installing a CAI and probably uprated fuel pump along with TIP and bigger intercooler
okeej uprated fuelpump didnt see that one coming whats the limit for the original fuel pump
Not so much what's the limit, depending on the mileage of your Octy, the original pump could be getting tired and may not be able to supply enough fuel higher up the rev range, new pump or something like a Sytec will help.
its got pretty low mileage 148000 kilometers
when is it best to get an upgraded fuelpump ?? the guy that did my stage 3 map sad the fuel is spot on now as it is
Edited by rsdanne
So about 92000 miles, mine has done 131000 miles(about 210km) and the pump can't flow enough higher up the rev range, new pump to be bought and then mapped.
You could do with swapping your TIP, fitting a FMIC you should then get more out of it, you will probably find out how good your pump is then.
This is the upgrade, straight-fit fuel pump for a vRS:
http://www.motorsport-tools.com/sytec-hi-in-tank-fuel-injection-pump-36mm-in-8mm-out-p30311.html
Don't bother upping the fuel pressure, just use the standard 3 bar regulator, as your bigger than standard injectors should be able to cope with the power lever you are looking at. Running pumps and injectors at higher pressures puts unnecessary load on the components.
okeej thanks mate do i need to upgrade the fuelpump this early with the mods i have ??
It doesn't matter what mods you have. What does matter is how the pump is coping with the demand for fuel at high revs. I did everything all in one go as I didn't want to arrive at my mapping session and then find out part way through that my fuel pump wasn't good or my fuel filter blocked or injectors too small etc. etc. For the sake of GBP 50, I would just get it done, especially at that mileage
aah okeej but i just got my car mapped at stage 3  and  the fuel was spot on  he checked and logged with vcds and everything worked  perfect together  with the stage 3 map
Then leave it all alone and just enjoy the car.
okeej will it be any diffrence after i change to bigger tip and fmic or do you think the fuel  mixture is the same as it is now
Edited by rsdanne
Hmm. Difficult to say really. Is it a standard turbo intake pipe and intercooler you have at the moment? If the new setup flows better then it could change the fuel mixture, but the standard wideband lambda might be clever enough to sort it out. I'd fit the parts and then check the mapping.
at the moment it is  the original tip from turbo to airbox and the intercooler is also standard
i will be changing the  tip soon as im about to order one  from ebay
the guy that mapped my car said  that the maf will make the fuel mixture right and that it was just to change the intercooler and the tip/hose from turbo to airbox/maf
Edited by rsdanne
