Dim dash lights
My left indicator and speed regulating system dash lights are occasionally lighting up together. They're not at full brightness, you can just about make them out. They're on the whole time the ignition is on. They could do it for a few days and then they'll be off again.
Have you heard what causes the fault? I haven't seen much detail in the other threads. I work with electronics and I'd be confident changing parts. Diagnosing the problem may be difficult though. Also if it's not repairible, can I just fit a new one straight in?
Only going on what I've read on here over the years but dry solder joints came up quite a few times.
Most people had their clusters removed and sent away to a specialist for repair.
  HI ..car last used for a 360 mile round trip over Christmas ..half of which was with lights on .no faults what so ever....
car than not used till yesterday? with faults 1st time ever seen.
when started warning BULB ERROR malfunction came up checked all lights
was all working........ turned off ignition  ...restarted all was ok till 1/2 mile up road...
than dimly lit  lights on combination meter was noticed..
high resistance some where??
a bulb about to fail???
  • 5 years later...
Hi
Did you ever get to the bottom of this issue?
I now have the same problem and could do with a pointer....
