TA-Technix Germany Coilover Kit
TA-Technix Germany Coilover Kit are they any goood?????
They look cheap, get AP, most people consider them the minimum standard for decent coilovers.
AP any reccomendation to get them from. Tryed ebay but i want a complete kit with drop links and top mounts
You won't get coil overs with top mounts and drop links normally. You would have to purchase them seperately.
Getting a complete kit with ta coilovers for £280 on ebay. Includes drop links and front and rear top mounts
TA-Technix Germany Coilover Kit or FK coilovers ??
Dont want to spend much
TA are crap, FK marginally better but still crap.
I believe AP are only about £325. You don't need droplinks unless you're going silly low and you don't need topmounts either since they're very rarely worn.
Don't buy crap to pinch a couple of quid, you'll regret it. Badly.
My bad, they've gone up a bit.
Mind you I just got the Bilstein B12 Pro kit for £522 which is £30 cheaper than DPM, so...
That was just an example, I'm sure you can get cheaper.
So use lot are saying ap coilovers. Ima lower it about 50mm just abovr the tyre size (1 finger space) will that be aryt without getting the droplinks
AP have raised drop link mountings so standard length drop links are fine.
