Inlet Manifold Flap wiring details 2.0 TDI
Inlet Manifold Flap wiring details 2.0 TDI  engine code BKD
(also known as the Anti-shudder Valve)
The wiring loom and the plug to the above has been severely damaged and cut. I've managed to get a replacement plug but need to know which (colour) cables go to which pins on the IMF. Can anyone please advise?.
Edited by volleyer
I forgot to mention. Loom cable colours are Brown, Blue+Red & Violet+Light-Blue, Violet+Yellow.
The Violet+Yellow cable seems slightly thinner.
  • Sponsor
If no-one is willing to go and look at their car to help you, you could download the relevant wiring/current flow diagram for a small (£6 or so) fee officially, via erWin Skoda.
Thx for the suggestion Wino. I've not used erwin before so not sure if Id find the info there. I'll give it a go if I can't get help from anyone else after a couple of days. Shame as I think it should be a case of simply looking under the bonnet as the connector quite high up in the middle of engine at the front
Hi I have 2L TDI BKD I just popped out and took some photos in the dark hope they help.
Just took another in good light looks better.
ASV conector plug
  • 4 months later...
Cheers Pierssy, sorry its taken so long to say thanks but still much appreciated.
