Upgrading turbo to PD150 on BLT engine...shopping list
As per title, what do I need to buy to be able to do this?   Swapping KKK to GT1749vb. Many say it's a straight swap, but some say lower boost pipe needs work, which oil feed pipe- seen varius shapes+ braided, gaskets etc.  Ideally from someone who has done it in the past, any advice is really appreciated.
Thank you,
Mike
It should be a straight swap apart from the egr pipe will need blanking off.
Boost pipes should be the same.
Oil feed + return should be the same.
When people say the boost people needs work, its possible they are meaning it needs to be clocked. Basically the housing could be sitting in a slightly different position so the pipes dont match up as easily.
Compressor bolts need removing and the compressor housing rotating 90 degrees then bolt back up.
I got mine from Xman750 and he arranged a Garrett on a BLT manifold so there was no issue with the EGR. You can do it with an ASZ manifold but it's much easier to blank off the EGR valve on the BLT manifold.
brilliant write-up, i'm bookmarking this thread for when i upgrade later in the year
did you mean this turbo inlet pipe seal/ 'O' ring?
http://www.ebay.co.uk/itm/VW-Golf-MK4-Bora-1-9-TDI-Turbo-Inlet-Pipe-PD130-ASZ-PD150-ARL-1J0-129-627-D-/221522051645?hash=item3393be423d:g:0AEAAOSwT6pV1yWT
...and why do I need inlet manifold gasket?
cheers
Removing the inlet gives you more room and is essential if you bring the turbo out through the top.
The braided oil feed is a good investment as the solid pipe can break. Also means you can attack the feed to the turbo when it's off the car.
The braided feed can be had from Darkside.
Remember to pre lube the turbo with a bit of oil too. New exhaust and exhaust manifold nuts are a good idea too.
Ive done this myself a few times and it is pretty simple. Once you do it you'll be able to dona turbo swap in a few hours.
I'll have it done by a garage, so I think they will remove it from the bottom... can the inlet manifold stay untouched?
Yep, I've removed plenty from the bottom alone. Drive shaft needs to be removed but that's it.
looks like I've already bought a wrong oil feed pipe FFS.   it shows it's correct for the BLT engine but surely the turbo wants screw in type :((      but what's on the engine side?   What's the correct one for PD150 and BLT engine?
7C528755-F6B1-4E88-93BD-54B8A3982A00_zps
76434FB1-5F93-4819-AD38-7808AC5343C1_zps
On your old turbo where the oil feed screws onto can be undone and transferred over.
oh great, so it not a f**k up then?
No it's fine.
Get new copper washers though
