Dtc code help fabia 1.4 mpi
Hey guys i am getting a fault code of p0107 manifold absolute pressure/barmatic pressure curcuit low would this mean the map sensor is faulty ? The car is spluttering/missing and the epc light and eml is on could bbz engine i have changed the plugs and all 4 pencil coils and still the same as it was before
Thanks guys
I'm guessing it's not an MPI then and is a 16v?
Check for vacuum and manifold leaks, it sounds like air is being drawn in somewhere.
You can get a manifold pressure fault due to a misfire. I'd have a look at the misfire counter and cylinder recognition with VCDS and see if you can pin the issue to a cylinder.
Its a 16v yes
