Maxidot
Ill be wanting a maxidot display when i get my columbus.
So it got me thinking,can a FL cluster be fitted to a PreFL 2008.
Ok brilliant,,Will that mean the needle sweep? Could i have the blue dials?
Also does it need to be a specific set of clocks or just any FL set? I suppose if i want blue needles id need them from a scirocco?
Thanks Eddie
Only a instrument cluster from a MK2 Octavia will fit, a cluster from other Skoda's or VW's will not physically fit even they are electrically compatible. I would also suggest you get one for the right fuel type to preserve the redline on the dials.
If you want blue needles, you'll need to take the cluster apart and replace the LED's responsible for illuminating the needles. Tricky but doable...
As for staging (needle sweep), I believe most FL maxidot cluster should support it although I'm sure I've seen a couple of reports where it hasn't, possibly down to firmware version?
What i meant was for the maxidot part,extracting the maxidot from another set of clocks,but if the whole unit can be changed then happy days. save alot of messing around.
Eddie can you pm me with prices ect,are you in my area at any time?
Eddie I would be interested in a quote also'
Are all the fuctions on an upgrade available?
Do the Preface and Facelift versions differ at all?
sorry for the questions.
What will work / Display (Facelift Cluster)
in a Pre-Facelift
Navigation (Columbus & Amundsen+)
Audio
Phone  (7P6 + 3C8 modules)
Some settings
Unfortunately Convenience and Lights and Vision won't
Ive noticed i have a phone setting on my stream.does that mean i have BT or did the stream not have that option?
