Fault code help please
So I did give in and buy a Ross Tech Micro-CAN for £155. I am getting my head around it, and reading around to make sure I maximise its features. For starters, a bit of help on these detailed fault codes would be fantastic. (Edited to remove ones which were okay, my questions in bulleted italics, instructions from Ross Tech wiki in bold italics)
Thursday,14,January,2016,14:29:03:06063
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 213220km-132488mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H42---    Serial number: SKZ7Z0G4344981
   Coding: 0000072
   Shop #: WSC 23040 210 94682
   VCID: 73CB17F812A287A67C-8026
1 Fault Found:
000665 - Boost Pressure Regulation
               P0299 - 006 - Control Range Not Reached - Intermittent
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 212921 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:06:20
             Freeze Frame:
                    RPM: 2688 /min
                    Torque: 344.0 Nm
                    Speed: 93.0 km/h
                        99.45 %
                    Voltage: 14.13 V
                    Pressure: 2492.1 mbar
                    Pressure: 1959.6 mbar
  • Check Hoses/Pipes to/between Components: where exactly are these hoses?
  • Check / Clean / Replace Charge Pressure Control: where is this?
  • Check Turbocharger: how exactly?
  • Check Diverter Valve: how?
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 45AF99200CB6491602-8010
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
  • I used the HVAC module to reset the flap, but this error still came up. What next?
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005073397
   Coding: C18A0F130004140000110D000000000000197F065C000000000000000000
   Shop #: WSC 73430 790 00000
   VCID: 71C71DF068BEB5B68E-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 310707 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     200807 046  0204
   Coding: 00471077
   Shop #: WSC 73430
1 Fault Found:
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 213131 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.20 V
                        OFF
                        OFF
                        OFF
                        ON
                        OFF
  • Wiki has subsections for 'Short to Plus' and 'Electrical Fault in Circuit'; not for 'Intermittent'. Anything I can do about this or ignore since it's intermittent?
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1DM5LP
   Coding: 0020788
   VCID: 3D5FF1C0646601D65A-8068
   Subsystem 1 - Serial number: 6332MSME22122C653
   Subsystem 2 - Serial number: 6342MSME227374625
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
  • Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored: it's not terrible cold here in Cambridge. Blame the weather or get a new battery?
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74C914E417AC809E65-8020
4 Faults Found:
00884 - Ignition Switch (D) Terminal X
            012 - Electrical Fault in Circuit - Intermittent
00885 - Ignition Switch (D) Terminal 50
00576 - Terminal 15
01744 - Ignition Switch Terminal P (D)
  • It seems these four appear like a syndrome. RossTech says: the most common cause for this is the Ignition Switch (Electrical Portion). Do I need to replace the ignition switch?
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 99801A085283007F3F02050FC0085F96907C00
   VCID: 032B47384202B7266C-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H07 9001
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 16
                    Reset counter: 116
                    Time Indication: 0
  • Check/Repair Wiring/Connector from/to Interior Monitoring Sensors: what and where are these sensors?
As ever, thank you so very much!
I get the last one periodically, especially when it's cold. The sensor is in the roof near the rear view mirror, behind the two grills. My alarm still works correctly so I wouldn't worry too much.
Sent from my D5803 using Tapatalk
Thank you so very much, thats one I can rule out now. Which sensor is that...the rain/light for the wipers? Or the IR connected to the security alarm?
It's the alarm sensors, I think they're ultrasonic.
turbo - sticky vanes. vacuum hose leaks. damaged turbo. it is like needle in hay stack. unless, I see I can't tell. It looks like standard +-400mbar range was triggered. usually sticky vanes in turbo or leak
air flap - looks like dead servo in clima
I totally understand, it's hard to diagnose remotely! Would I be able to use any more of VCDS magic to narrow down the list of causes? Any particular parameters to log then put on a graph to help?
ill search here to see how people sorted sticky vanes
where are the vacuum hoses for me to check for leaks? I read somewhere about disconnecting one end and sticking a bicycle pump in one end to see if it holds pressure.....would that sound right?
damaged turbo....please dont tempt fate!
dead servo in climate control? Okay, Ill search on here and find a fix!
VCDS has got a function of controlling all active controllers. You don't need to blow out manually.
You can test N75.
Sticky vanes are simply to test. Warm up your car. then drive on flat road on third gear...let revs drop to 1500 and then flat out. Turbo starts to kick at around 1800 or 2000 if 1.4TDi. Or you can push it very hard with hard turbo use and vanes stick in no time
ETKA + VCDS and GOD is DJ
Thanks, Mike. I will run through what you have kindly advised and get back to you. I agree, clearing codes singularly will give me the learning experience I need.
MIke, I don't believe this!
I cleared the codes individually and only a new one showed up! (02390: i think i somehow activated footwell lights on VCDS coding....I'll retrace my steps and undo).
Given that you said the intermittent issues are down to low voltage and likely cold mornings, I'm sure part of the solution has been the new Bosch S5 I fitted last week after having to call the recovery in the morning for a jumpstart when my booster pack wasn't enough to get it going. (The battery was old anyway and end of life anyway).
I could have sworn I cleared codes and reran them before posting my original post in this thread. Although then, I used the 'clear all DTCs' option under the autoscan module and not individually through the control modules, as per your advice. I'm guessing they didn't clear properly for some reason and doing them individually is the way to go.
Resetting the HVAC flap also solved that. You mentioned they tend to become periodically sticky...is it easy to disassemble and give a thorough clean?
In terms of working out if sticky vanes is the turbo issue (it feels like there's a turbo lag), could you advise which blocks to measure continuously and plot on a graph? When I have time, I intend to follow the steps here: https://sites.google.com/site/1810martin/vcds-and-pd-tdi-engine-health-check
As ever, thank you very much!
