1.2 6V AWY compression test results
Done on a cold engine
1st cylinder = 14 bar (203 psi)
2nd cylinder = 8 bar (116 psi)
3rd cylinder = 12 bar (174 psi)
Should I be worried about these results?
Edited by harkinian
Does it not misfire with them results?
I havnt checked auto data but suspect cylinder 2 is way out of tolerance.
Hutchy is right, cylinder 2 is terrible, your exhaust valves are burnt which means the head needs to come off and be reconditioned.
Yup cylinder 2 is way down.. almost certainly the valve guides that are worn causing the valve not to seat properly.
